Go Back   FordMuscle.com Forums > Premier Forums > Advertiser Announcements
03-20-2008, 10:10 PM   #1 (permalink)
Mikelonis
6 Cylinder Mustang Screamin' Demon
Spark up your 6 cylinder Mustang with Performance Distributors’ new Screamin' Demon ignition coil. This is the first performance coil for '05-'07 6 cylinder Mustangs! Dyno-tested providing 14.3 more hp and 12.2 more lbs. of torque over a stock ignition system. Designed to produce a longer duration spark, the Screamin' Demon burns your fuelmore efficiently. In fact, you can open up your spark plug gaps to an astounding .060"-.065” when you run theScreamin' Demon coil. That’s a spark that will put a real zap in the seat of your Mustang 6! Also, your spark plugs will stay cleaner longer. In addition, the intensity of the Screamin' Demon's spark does not drop off as your rpm’s rise, as is common with stock ignition systems. The Screamin' Demon is easy to install, requiring little time. The coil is epoxy filled, leading to improved heat transfer and vibration resistance. Mounts in the original equipment location.
For more information, contact...
2699 Barris Dr.
Memphis, TN 38132
(901)396-5782
Performance Distributors - High Performance and Racing Ignition Systems
03-20-2008, 10:32 PM   #2 (permalink)
Re: 6 Cylinder Mustang Screamin' Demon
I want one for my 65-67 STRAIGHT six motors.... What you got for me?
03-21-2008, 02:29 PM   #3 (permalink)
trashline
HAHA thats what I thought it was for...
65 mustang
custom mustang parts
http://www.geocities.com/levittownfire1/BCP.html
65 Mustang - Converting from 6 Cylinder to V8 bgoldman All Ford Techboard 2 05-26-2004 01:07 AM
SCREAMIN’ EAGLE/VANCE & HINES V-ROD WINS GATORNATIONALS DynoTom The Garage 19 04-06-2004 01:00 PM
5-Speed conversion for 88 mustang 4 cylinder 4cylindermustangracer All Ford Techboard 1 09-04-2003 02:34 PM
Is it my Master Cylinder or Wheel Cylinder? andysam All Ford Techboard 3 07-15-2003 12:30 AM
demon jr. carbs!!! any good compared to they're daddy demon sr. carbs? XolieX All Ford Techboard 1 10-28-2002 07:13 PM
Hays Clutches
