Go Back   FordMuscle.com Forums > Premier Forums > Advertiser Announcements
04-29-2008, 12:45 PM   #11 (permalink)
sdavis
Re: Mini-VIP 18 Viscious Volts
Originally Posted by mustang42782 View Post
This device has been outlawed by IMCA and NASCAR for circle track racing.
We did not know that it had been banned by them. We used to make an 18 volt battery that was banned due to the rule against running 2 batteries.
But we thought that our 18 volt step-up Mini-VIP would be legal.
sdavis is offline   Reply With Quote
04-29-2008, 12:50 PM   #12 (permalink)
sdavis
Originally Posted by dbu8554 View Post
I just gotta say big ups to sdavis he seems to be answering alot of questions and not losing his cool at all I know some people have a hard time with that but its nice to see a vendor out there answering questions.
Also since its been banned by nascar does that mean it works?
Oh yeah how would something like this effect a Distributor less Ignition System such as fords EDIS just wondering thanks alot
You just splice into the power wire(s) going to the ignition coil(s).
The unit has a diode inside of it that isolates the 18 volts to your ignition coils.
04-29-2008, 12:53 PM   #13 (permalink)
sdavis
Originally Posted by dutchlincoln79 View Post
If it would be beneficial, most car manufacturers wouldn't put a resistor in series with the coil, they'd put a step-up converter between the coil instead...
CD boxes do not gain anything, as they have a equal device built in... (they can run as low as 9 volts, to up to 24 volts, with equal performance... Says enough...)
The oem's used resistors to prevent from burning up points and coils.
Keep in mind that the Mini-VIP is NOT a cd box.
Is 14.5 volts too much? southern63gal All Ford Techboard 2 10-03-2007 09:54 AM
Coil amp.and volts gresse All Ford Techboard 21 03-30-2007 03:57 PM
battery volts while charging??? sharpshot71 All Ford Techboard 3 03-04-2007 08:51 PM
Duraspark and 12 volts? indigo66 All Ford Techboard 4 01-07-2005 01:58 PM
how many volts can a coil handle pedal2themetal45 All Ford Techboard 19 06-10-2004 03:02 AM
