State of the art Digital Nitrous Control System allows the user to control how much and when Nitrous is delivered to the engine. This helps to prevent engine and or drivetrain failure while allowing greater control in traction and performance when using your nitrous system.
Where to Buy
Part No. 74186
Features and Benefits:
* RPM Based Nitrous Control
* Time Based Nitrous Control
* RPM & Time Based Nitrous Control
* Pulse Width Modulation Control
* Ignition Timing Control
* High Speed Timing Retard
* Nitrous activation delay timer
* RPM activated switch
* Over REV Limiter and 2 Step REV Limiter
* Fuel/N2O offset (Help to prevent backfires)
* System can be triggered from a throttle switch or a TPS sensor on EFI Systems
* Will control a fuel and nitrous solenoid requiring up to 25 AMP draw.
Application: Universal 4-5-6-8-10-12 cylinder, Nitrous Equipped Applications.
