Go Back   FordMuscle.com Forums > Premier Forums > Advertiser Announcements
09-10-2008, 01:08 AM   #1 (permalink)
Mikelonis
ACCEL Pro 25 Race Wire
Looking for that Winning Edge? The PRO’s know to use ACCEL Pro 25 Race Wire - and so should you. The ACCEL Pro 25 Race Wire offers incredible RFI noise suppression at only 25Ohms per foot of resistance. The special Race-only wire uses a Ferro-spiral core that is machine wound to allow maximum spark energy to the plugs.
The red wire jacket features a double silicone construction that is rated at over 600° F. This extra layer of silicone is designed to better resist extreme heat variances, petrochemicals and excessive moisture. The special Race Wire terminal uses a combination of stainless steel and brass for unsurpassed electrical conductivity and excellent corrosion resistance. Using Kevlar strands on the inner core provides greater pull strength and robust terminal retention.
Available in Universal and Custom Fit applications - with optional Pro-Sleeving for greater protection against heat. See Product Flyer
"I always run high quality ignition wires on my race car. So I really didn't expect to see a difference when I switched over to the ACCEL Pro 25 wire, but I did! I actually picked up more mph and I ran 2 tenths faster in the ¼ mile. I am a believer and will not run anything else. I’m truly amazed!" Jon - Springfield, OH
Where to Buy
Accel 300+ Neal Mustang Pages (1965-1973) 0 12-15-2005 02:56 PM
\"Bird on a wire\" yes? But, \"car on a wire\" no?????? Strange PIC! DynoTom The Garage 13 12-27-2004 04:04 PM
multi wire to one wire alt change?? pedal2themetal45 All Ford Techboard 3 11-22-2003 08:47 PM
Has anyone used the Accel 300+ ignition? Wookie1 All Ford Techboard 2 11-17-2002 03:03 AM
EFI 429 slow to accel shawboy61 All Ford Techboard 4 05-30-2002 10:04 PM
