The DFX® series by Centerforce ®, the next level in high-performance is now available for 1983 to 1988 Ford Mustang and Thunderbird / Mercury Capri & Cougar with the Turbo and Non Turbo 2.3L engine. This new clutch assembly replaces the stock clutch & flywheel assembly with higher holding capacity pressure plate designed for a direct bolt in replacement. Centerforce strives to provide the best products on the market today on all performance levels by using patented processes and constantly testing different materials and designs to find the best combination.
The DFX series is the latest of extreme performance clutches from Centerforce designed as a direct bolt in for perfect fit and function. DFX scores big, not only with holding-capacity and strength, but also provides some of the best drivability from a race-inspired clutch. This DFX performance clutch system utilize the patented Centerforce centrifugal weight system for maximum grip, a patented Ball Bearing design for light pedal and quick release, Nodular Iron pressure plate rings and reinforcements designed to help prevent drive strap breakage and safety. The Paddle or button style disc has been through constant testing of different friction materials and hub designs to bring the best possible combination available to you.
The DFX part number
01228038 (Pressure Plate and Disc),
11228035 (Pressure Plate), and
23228035 (Disc) are now available. Please contact any Centerforce dealer or Centerforce directly with questions at (928) 771-8422 or visit them online at
Centerforce Clutches.
