Go Back   FordMuscle.com Forums > Premier Forums > Advertiser Announcements
04-13-2009, 12:12 AM   #1 (permalink)
Mikelonis
The Boss is Back!
TMeyer Inc. has completed development of three new piston designs for Cleveland-Headed "Boss" Motors. These latest piston designs have enabled TMeyer Inc. to offer a complete line of stroker kits for use with 302, 351C, 351W, and 400 block motors with Cleveland-style heads. If you are eager to break away from the small block Ford pack or are simply a "canted-valve" die-hard, then you'll be pleased to see the opportunities created by this unique line of pistons for various strokes, rod lengths, and blocks.
TMeyer Inc. Cleveland-Headed Piston Chart
• All pistons are for the Cleveland heads
• All pistons are flat top
• 14cc dome pistons are solid and can be removed
• 4.125" optional bore size for aftermarket blocks
Take note that a solid dome is available for 302 blocks with stock rods and open chamber Cleveland heads. This will allow a very easy 302 Boss that can survive with today's fuel.
Pistons may be ordered as part of a rotating assembly, balanced, or in a short block, long block, or complete dyno’d engine. You can have a Boss in any configuration with TMeyer Inc. (Cast and Forged Crankshafts. I-Beam, H-Beam, Lightweight & Extra Lightweight I-Beam connecting rods also available)
Big Boss 454 Stroker Kit
In addition to pistons for 302, 351C, 351W, and 400 block motors with Cleveland heads, TMeyer Inc. has also developed a 4.125" bore piston designed especially for 4.125" bore aftermarket Windsor blocks running Cleveland-style heads. Inquire for more information. The same 4.125" bore piston is used in the TMeyer Inc. Big Boss 454 stroker kit spec'd below.
• Aftermarket 9.500" block Cleveland mains and 4.125" bore
• Forged 4.250" stroke crankshaft
• Forged H-beam connecting rods
• Forged flat top pistons
• Rod and main bearings
• Premium moly ring set
• Price - $3500
Ask for a quote on other combinations or see The Boss is Back! at tmeyerinc.com.
TMeyer Inc.
1121 Marcus Street
Fairmont, MN 56031
(507) 238-4141
TMeyer, Inc. Precision Automotive Machining
08-22-2009, 03:05 PM   #2 (permalink)
tmeyer
Re: The Boss is Back!
We now have the sources to have custom pistons made for that "off the chart" application.
Customs will range between $550-$650 a set. Flat top piston are on the low side, domes higher priced.
tmeyer is offline   Reply With Quote
Leaking Back Glass- '64 Fast Back R428Galaxie Galaxie Pages 8 03-12-2009 12:40 PM
302 Boss davidshafer Mustang Pages (1965-1973) 7 02-11-2008 07:48 AM
351 Boss Deester Wanted 1 12-28-2007 07:04 AM
BOSS mlanden The Garage 1 07-05-2004 09:21 AM
New Boss 302? HitmanKB The Garage 6 03-28-2003 11:52 AM
