Having Detonation Nightmeres!
Your problem lies in your camshaft and not your static compression!!With the right cam timing you can run a static compression motor of 12 to 1 with the right camshaft and not even worry about detonation!!PLEASE talk to some of your RACING machine shops around you or talk to a CAM specialist!! Lobe separation,lobe centerline,cam overlap is what effects detonation!!!Hope this helps,because I've done this already!!!
