01-12-2002, 06:31 PM   #1 (permalink)
dragman64
oil pickup clearence
How far away should the pickup be from the oil pan???
dragman64 is offline   Reply With Quote
01-12-2002, 06:42 PM   #2 (permalink)
dark7068
1/4-1/2 in. I believe. Books I have say parallel with the pan mounting flange for a stock pan.
dark7068 is offline   Reply With Quote
01-12-2002, 06:58 PM   #3 (permalink)
89 coupe
Actually 1/4-3/8" but I prefer 3/8" with a high volume pump otherwise you can cause too much suction and cause oil "stall" and cavitation of the pump. 3/8" gives enough clearance with high volum oil pump and loose clearances to avoid the possible problems.
89 coupe is offline   Reply With Quote
