01-15-2002, 11:58 PM   #1 (permalink)
bullet
cam "o" cam
building a 351w, have two cams. can you guys give me the pro's and con's ?
cam#1
492/480 lift
262/270
.050 218/224
112 l.c.
cam#2
284/294
.050 224/230
510/510 lift
108 l.c.
both flat tappet
bullet is offline   Reply With Quote
01-16-2002, 03:05 AM   #2 (permalink)
89 coupe
cam "o" cam
Cam 2 unless you have stock single exhaust, stock converter, and a 2bbl. Cam 2 can be used with Rhoads lifters if using a stock converter but without knowing anything else other than it's a 351W, I still pick cam 2 knowing it has a 4bbl and dual exhaust. Rhoads will make cam #2 work with stock converter.
89 coupe is offline   Reply With Quote
01-16-2002, 03:05 AM   #3 (permalink)
89 coupe
cam "o" cam
DOH!
<font size=-1>[ This Message was edited by: 89 coupe on 1/16/02 2:06pm ]</font>
01-16-2002, 03:05 AM   #4 (permalink)
89 coupe
cam "o" cam
DOH!
<font size=-1>[ This Message was edited by: 89 coupe on 1/16/02 2:08pm ]</font>
01-16-2002, 09:16 AM   #5 (permalink)
bullet
cam "o" cam
bigs 750 carb,headers,ported heads, bigger valves,3" flowmasters,forged pistons,9.5 to 1 comp,roller rockers.that is the 351w
