01-16-2002, 02:06 PM   #1 (permalink)
rod n az
MSD 6A installation
I recently installed an MSD 6A ignition box on my car. I've had my battery die on my twice so I replaced it with an Optima yellow top. I haven't driven my car since then.
But in the 6AL installation in the ARCHIVES, it shows the heavy red power wire going to the starter relay and the heavy black wire being grounded to a voltage regulater screw. But when I installed my 6A, the directions said to route each wire to the battery terminals. Which is correct? Does the box draw power from the battery even when the car is not running the way I have it installed? If I routed the wires the way they are routed in the tech article and not the way the inscructions said to, will it solve my battery issue?
rod n az is offline   Reply With Quote
01-16-2002, 05:28 PM   #2 (permalink)
lordviper13
MSD 6A installation
did you route both of the red wires to the battery
if you did that is your problem, the heavy red goes to the battery + and the black to a good ground. The small red goes to a switched power(somewhere in the fuse panel works)
hope this helps
lordviper13 is offline   Reply With Quote
01-16-2002, 06:19 PM   #3 (permalink)
rod n az
MSD 6A installation
I just looked at my wiring and here is how it is.
heavy red goes to the postitve battery terminal
heavy black goes to the negitive battery terminal
small red goes to the starter relay terminal, marked "I"
white goes to the distributor
orange goes to the positive terminal on the coil
small black goes to the negitive terminal on the coil
Is there anything wrong with this?
<font size=-1>[ This Message was edited by: rod n az on 1/17/02 5:20am ]</font>
01-17-2002, 09:59 AM   #4 (permalink)
Fomoco8
MSD 6A installation
Are you running points , Duraspark or other type distibutor? small red goes to switched ignition (ususlly the original + side of coil to ignition switch, white is usually not used except in points and it goes to the - side of the coil
Fomoco8 is offline   Reply With Quote
01-17-2002, 02:09 PM   #5 (permalink)
rod n az
MSD 6A installation
Yes I have a point distributer.
01-17-2002, 05:28 PM   #6 (permalink)
Fomoco8
MSD 6A installation
Okay easy fix, Heavy red to + plus side of battery, Heavy black to - side of battery, red and orange to positive side of coil, and black and white to negative side of coil,
01-17-2002, 06:00 PM   #7 (permalink)
rod n az
MSD 6A installation
If I did it that way, how would the ignition be switshed on when I turn the key? Would it always be on?
01-17-2002, 09:51 PM   #8 (permalink)
Fomoco8
MSD 6A installation
when you turn the ignition to ON there is wire from the ignition switch to the + side of the coil, that is also connected to the MSD and hence gives the box its power,thats all there is to it, the box will be on if the key is in the ON position and start positions only!
