Manual Transmission in a 94 GT??
Yes, they are a T5 just like the older stangs use. But I believe they are 5/8" longer so you must use the 94/95 bellhousing with this tranny. Yes it will have the shifter back a little further than the earlier T5's, so a little notching might be nessesary. But still a good tranny to have.
Just be aware, if its too cheap, something could be wrong with it. Make sure you can go through the gears and turn the input shaft.
