squeeling startup
You should try looking and examining the pully's with the belt removed. There may be varnish that has built up on the pully's themselves that allows the belt to squeel. The problem with the belt dressing is that it allows the belt to slip, which is not what you want happening. I don't know if you can do this, but can you put more tension on the belt itself? Thats what I would do. Good luck!
