I aleady have the Performer, and it's like the thing has a governor on it. I would like to get 7000 RPM's out of her, but don't want to kill my low end torque. I have hydrolic lifters, and the spec card for the cam reads;
cam lift- int .281 exh .296 valve lift- int .486 exh .512
lobe ctr- int 106 exh 118 SAE duration-282 int 292 exh .050 duration- 204 int 214 exh
maybe you guys can tell me what these #'s mean. It doesn't lop like a heavy cam, but it does run good. it is an RV.
so, how can I get this Blue Thunder? does Probe Ind. have a web site?
2 Q's, what cam is this? and whare to find blue thunder?
The first thing that you should consider if you want to spin your engine to 7000 RPM is getting a solid lifter cam. Hydraulic cams can be made to spin to 7000 but the tappet deceleration rates of the lobes themselves have to be mild and the valve train components quite light. A solid will make more power everywhere in the powerband and will make more vacuum and fuel economy than an equivalently sized hydraulic cam will as well. The cam that you described is very small. It's even smaller than the 1972 266HP factory 351CJ cam. I'd recommend something like the Ultradyne 272/282 solid for your engine. It's advertised as being very streetable, idles with a slight lope and makes power from 2800 - 7000 RPM. You'll definetly know you have a cam in there and the low end torque won't be what it was with the little cam but it's the minimum you need to make good power to 7000 RPM.
Yes, Probe Industries has a website. Believe it or not it's:
http://www.probeindustries.com/
