03-30-2008, 07:18 PM   #11 (permalink)
doug351
Re: Metal bits in oil filter?
Originally Posted by Luv70sFords View Post
You can also feed a decent length of cotton cord in through the spark plug hole (leaving some hanging out so you can remove it) then use a wrench to crank the engine over, pushing the piston up. The piston compresses the cord againt the valves, so they will have no where to go.
Works like a charm.
That's cheating! Great tip. Thanks. Might come in handy some day.
doug351 is offline   Reply With Quote
03-30-2008, 08:39 PM   #12 (permalink)
60smuscle
What year is it? Also, does the engine run smooth and is it quiet around the timing gear area? I am also thinking timing gear coming apart unless it is burning/using a lot of oil, then I also would suspect valve seals.
03-30-2008, 08:56 PM   #13 (permalink)
ixtlan
Did anyone else notice this topic was 5 1/2 years old?
RatStang Restoration
Automotive Rotisserie Restorations.
Paint, Body, & Light Fabrication.
www.RatStangRestoration.com
03-30-2008, 08:59 PM   #14 (permalink)
60smuscle
Not me and now my face is red!
03-30-2008, 09:20 PM   #15 (permalink)
Luv70sFords
hahaha
thats happened a lot in the last few days I've noticed. This one caught me......
Oh well, its still a good trick.
Those that say it cant be done should say so quietly, so as not to disturb those who are doing it.
03-31-2008, 04:38 AM   #16 (permalink)
Mikes66
Originally Posted by Bumblebee View Post
There is a way but it requires a compressor. you run the piston to TDC so the valves are closed. There is a tool called an air hold which screws in in place of the spark plug then you pressurize the cylinder with the compressor to hold the valves closed. Then use a screw type spring compressor to remove the springs and replace the seals.
Keith/Bumble
Yes, this works fine. Have done it many times. I also agree it is the valve seals that have turned hard, craked and came out.
However...... You will have more of that stuff in your oil pan. You must flush it all out. Also the oil return holes going down to the pan should be checked for debree's.
I can not figure how that stuff got past your oil screen and then the pump without breaking the shearing pin, unless it is very small stuff.
One more note, if the engine has lots of miles, the oil seals are busted like you say, your plugs have oil on them, I am 100% promise you your intake valves are 50% blocked with hardened oil on them.
Taking the heads off it probably the best route to go if you want any kind of power, and gas milage with this motor.
[SIGPIC][/SIGPIC]
03-31-2008, 04:40 AM   #17 (permalink)
Mikes66
Crap. I got cuaght in the 5 year old trap....!!!!
[SIGPIC][/SIGPIC]
03-31-2008, 01:10 PM   #18 (permalink)
sharpshot71
i know its an old thread, but one thing i have heard about the rope in the cylinder trick, is to make sure you use cotton rope, not nylon. any cotten threads left will just burn up, but nylon will stick to stuff
03-31-2008, 02:42 PM   #19 (permalink)
torinojimmy
Originally Posted by frdnut View Post
Could be hardened old valve seals.Is this an old or high mileage motor?Sometimes if you look under the valve cover you can see broken chunks stuck in the oil return holes.
that is exactly what i found when pulling my valve cover...... now it makes sense, i know what those chunks are.
could any more be stuck throughout the bottom end, contributing to the extremely low oil pressure? (i didn't entirely rebuild the motor as i should've)
4.10's are highway gears
torinojimmy is offline   Reply With Quote
03-31-2008, 03:09 PM   #20 (permalink)
doug351
Hey, it takes me a while to get around to doing some things. I meant to answer it 5 years ago, but I got busy.
