06-05-2002, 07:34 PM   #1 (permalink)
Cheesycook
Starting when hot
Hey fellas,
I had a brain fart. When a car won't start when it is hot out, was that usually a starter solenoid problem?
Cheesycook is offline   Reply With Quote
06-05-2002, 08:50 PM   #2 (permalink)
mustang68mustangs
Starting when hot
I had this problem. My starter was getting heat soaked because it was too close to the headers. I put on a wraparound heat shield blanket on it and cured the problem.Gm products usually have this problem because the solenoid is on the starter.
Bob
mustang68mustangs is offline   Reply With Quote
06-05-2002, 08:51 PM   #3 (permalink)
mustang68mustangs
Starting when hot
Bob
06-05-2002, 11:56 PM   #4 (permalink)
only126db
Starting when hot
had the same problem even with heat blanket...had to get high torque mini starter
only126db is offline   Reply With Quote
06-06-2002, 12:23 AM   #5 (permalink)
Luv70sFords
Starting when hot
Could also be timing thats too far advanced. Does the vehicle even have headers? If so it could be heat soak, but not likely due to fords starter designs. My 460's starter is practically encased by the header, and I havent had any heat soak problems. Id also check to be sure that your connections to the battery are clean, and the cables are in good shape. Do some of your basic checks, and move on from there.
06-06-2002, 08:13 AM   #6 (permalink)
Just Strokin
Starting when hot
how old is this starter? It could be the bushings are worn allowing the armature to drag against the field coils or be too close. I have never seen a Ford solenoid on the fender go bad in 30 years. I know some that have had them go bad, but very infrequent.
As others mentioned, check the timing and possibly replace the starter.
06-06-2002, 09:22 AM   #7 (permalink)
Cheesycook
Starting when hot
Well, to be honest guys, it is a Honda Accord. But it's not mine!!! It belongs to a girl I kind of have a thing for. It is bone stock(no ricer crap). She had an intermitten problem getteng it to start before because the spark plug cylinders were leaking oil leaving the plug wires and sparkplugs submerged. I cleaned them out and replaced ger gasket. I checked the plugs and they are clean as a whistle. She still has problems starting on hot days, not neccisarily after she has been driving. I am thinking it is the starter solenoid because her ex replaced her old starter for her with a remanufactured model. She was so impressed by the guy and believed him when he said that this was alot of work. I had to break the news to her that it is only two bolts, as I had the upper end of her motor in pieces on the ground. Heh heh! [img]/phpBB/images/smiles/icon_smile.gif[/img]
06-06-2002, 09:38 AM   #8 (permalink)
Pale Rider
Starting when hot
You probably already know this but, remanufactured does not necessarily mean good. Check the solenoid closely. Other than that, I'd start looking at grounds. Good luck with the car and the girl!
Good to hear from you again Cheesy. Been a while. How's the Stang?
Pale Rider is offline   Reply With Quote
