302 motor build
Flat top pistons will give you approximately 9:1 compression with 64cc chambers. I'm running that block with Trick Flow TW heads and 61cc chambers for slightly more compression. It should work fine with your heads, you can adjust compression with gasket thickness to a degree, and/or by going with larger valve reliefs if you want to reduce compression.
