Removing the chrome side panals.
Those lil white tabs should have a hole that they slide to. If not, and you do not plan to put the moulding on again, start with a 3/16 drill bit and drill out the centre. Then, with a steady handgo to a 5/16 or 3/8 and just drill enough that the head of the rivet disappears. Save the tabs, you may want them in the future or find someone who needs them badly.
At this point, you should have a nib about 1/8" and using a Dremel or equivalent,with a cone bit slowly follow the 3/16 hole til you parallel with the body panel. How are you with body work / touch-up work? Once you have gotten to this point, the decision is your to either go just a lil more and then us a filler for the hole to make it flush, or find yourself someone who can spend 2 hours to finish it off for you. You can do it, just don't rush.
