07-24-2002, 04:56 AM   #1 (permalink)
64 TBOLT
over full
i've asked this b4 BUT,do converters drain back into the trans??Thats the reason the fluid is way over full when sitting for awhile.Is it normal,do they all do it,if not whats the problem/fix [img]/phpBB/images/smiles/icon_confused.gif[/img]
07-24-2002, 05:19 AM   #2 (permalink)
dragman64
over full
Are you checking it at idle, while in park?
-Walt-
1964 Comet 289 C4/3000 stall daily driver
TFS TW, Weiand Stealth, Comp XE268, Rhodes lifters, TFS roller rockers, Carter 625 AFB, Hooker SuperComps
"These go to 11." -This is Spinal Tap
<font size=-1>[ This Message was edited by: dragman64 on 7/24/02 5:24pm ]</font>
dragman64 is offline   Reply With Quote
07-24-2002, 06:22 AM   #3 (permalink)
393Clevor
over full
Mine does the same thing. It's fine when you check it idling but after it sets for a while (not running) the level goes way over full and it leaks.
07-24-2002, 06:57 AM   #4 (permalink)
gregaust
over full
What you've got is completely normal..[img]/phpBB/images/smiles/icon_wink.gif[/img]
07-24-2002, 07:50 AM   #5 (permalink)
Just Strokin
over full
The snout of the converter is above the pan and yes, after a few minutes/hours, the fluid above the snout will drain back into the pan. That is the reason the dipstick says to check in park or neutral at idle and warm.
