Cam bearing gone bad
Blue mentioned something that I hadn't thought of. Since the wear is at the bottom, you might have too much preload on your rockers or too much lift for the springs and the binding is causing excessive pressure. Have you checked your open and close pressures? 300 is the highest open pressure you want on the street.
