1968 390 z code exhaust leak
I just bought a 68 XL with the z code. It had an exhaust leak on the pass side. I read that these engines are somewhat prone to this problem to the point that sometimes if you let it go, the head needs to be milled to flatten the exhaust surface. I brought it to my mechanic who snapped a manifold bolt, retapped it, surfaced the head (still in the car) and the manifold with a 3m pad, reinstalled the manifold with a new felpro gasket and it still leaks.
He says that to fix it right, he'd have to remove the head and have it milled. OK, but then you might figure, why not take both off and have them rebuilt. He says that the FE engines don't take well to having just the top end redone, and that the increased compression will blow out the rings necessitating a total rebuild any way. He suggests I just live with it until I want to make the big investment.
Two questions: I assume that the exhaust leak will continue to damage the head surface. Will it also screw up the exhaust valve? Also, is there any truth to the new top end screwing up the old bottom end story? I gave this guy $300 for 6 hours of labor to fix a problem that isn't any better.
Thanks for your help,
Jason
