08-21-2002, 11:53 PM   #1 (permalink)
Fastback68
Are 11's Possible?
Ok here we go....
Got some new parts today this is what it currently looks like.
351C .030 over 357 cu in.
Roughly 11.5 to 1 compression
4V CC heads (port floors filled and flow benched)
Harland Sharp Rockers
Crower Cam Solid Roller 590/590 lift 242/242 duration 110 Lc
Motorsport timing chain
Full MSD ignition
Edelbrock Torker intake - matched to heads also filled some with epoxy
Holley 850
Hooker supercomp heads 1 7/8 long tubes
Dual 3 inch exhaust
3000 Stall C6 with street/strip shift kit
3.70 gears/posi 9" radial by day slick by night [img]/phpBB/images/smiles/icon_wink.gif[/img]
All in my 68 fastback
Any guesses would be great guys.
Fastback68 is offline   Reply With Quote
08-22-2002, 12:07 AM   #2 (permalink)
1970coupe
Are 11's Possible?
Very close to my combo except my cam is .570/.590 with 246/256 duration@.050. My best run so far was on an 80 degree day and ran 12.02@111.35. I run 4:11's and a C4 tranny. The C6 will slow you down by almost 4 tenths, I know this for a fact as I just took one out 2 weeks ago! I know with my combo I will dip to around 11.75 so you will see low 12's. I would have to say very hard pressed to see an 11 especially with that gearing and tranny otherwise yes!
1970coupe is offline   Reply With Quote
08-22-2002, 01:28 AM   #3 (permalink)
SteeLDawN
Are 11's Possible?
More gear, and less duration on the cam, because your range is too high.
go for less than 230 duration
SteeLDawN is offline   Reply With Quote
08-22-2002, 01:31 AM   #4 (permalink)
Fastback68
Are 11's Possible?
Wont that make it slower?[img]/phpBB/images/smiles/icon_confused.gif[/img]
08-22-2002, 03:10 AM   #5 (permalink)
xafalcon
Are 11's Possible?
To achieve your goal you will need more gear, and I'd also add a higher stall converter 4.11 / 3500 (to keep it streetable, 4.3 / 4000 if you just want a quarter miler). It looks like a great combination, have fun.
Good luck
Tris
xafalcon is offline   Reply With Quote
08-22-2002, 07:32 PM   #6 (permalink)
clevelandstyle
Are 11's Possible?
Put in more gear with a higher stall and the cam will be fine.
My combo is 351 4V closed chamber. 246/256 cam. I have gone 11.29@118 in a Fairmont body.
It can be done.
08-22-2002, 09:26 PM   #7 (permalink)
coolfalcon
Are 11's Possible?
Im with Chilly alot more gear. Have a friend with 351c 630 cam upper 260@.05 runs a 540 gear with a 4 speed low 10's. 93 mustang. Have fun with it.
