bypassing the smog pump please help
When you remove the air pump you remove the air that is needed to burn the fuel in your cats. After awhile you'll clog the cats, if you’re still using them. The pump puts air into the exhaust so the cat will work, without the extra air the cats clog.
Leave the pump on if you are still running the cats.
