My project is a 1979 mercury capri. the engine and transmission found there way gacefully to the junkyard in favor of a 40,000 mile 5.0 ho and 4 sp aod from a 1989 lincoln lsc mrk 7. the plan was to fuel inject it, money became a problem so i went into the garage and grabed a eldelbrock performer intanke and 600 cfm carb. now to the problem, the engine runs like a top, but the tranny is another subject. i took it for a test drive, lyed into the throttle and the 16" ponies melted but the damn thing stayed in 1st gear. knowing the tranny shifted firm and through all the gears in the wrecked donar car i started to scrach my head. reading through the many publications i found that what i thought was a passing gear cable is infact a throttle vavle cable, that determines shift point and tranny line psi. it was still hooked up the the original f.i. bracket so i cut and ground the bracket to fit the carb and set the T.V. so that at no throttle there was no play in t.v. and at w.o.t. the t.v. was at full extend. i am still using the stock t.v. i ordered an aftermarket lokar t.v. and ran it as far away form the exhaust as possible but it burned the plastic shething and redered it unusable ($112) down the drain. what i am asking is if anybody as done this say or simular swap and what it took to get the dang thing to shift right. also will s stock lincoln 8.8 w/disc brakes fit right into the place of my 7.5 pig of a diff? thanks for any feed back and i am sorry for the long post. email me with any long explinations at
bigikediesel@aol.com
thanks
Jay [img]/phpBB/images/smiles/icon_evil.gif[/img]
<font size=-1>[ This Message was edited by: bigikediesel on 9/22/02 2:07am ]</font>
