09-25-2002, 04:29 PM   #1 (permalink)
BLACK65FORDFALCON
Gasoline In Oil???
Hi, A couple weeks ago I was having a problem with low oil pressure at idle. I was using 10/30 oil and noticed that when I was idling that the lifters were rattling, And I was only getting about 8 psi of oil pressure. I imediately changed to 20/50 and that solved the problem but was more of a cheap cover up rather than a remedy. I than took my car to my mechanic and he said that there was gas in the oil because the car was running way to rich, and that the timing was way off. My question is is that possible to cause low oil pressure.
Thanks in advance.
BLACK65FORDFALCON is offline   Reply With Quote
09-25-2002, 06:16 PM   #2 (permalink)
wild4stangs
Gasoline In Oil???
If there was enough gas in there to thin out the oil, it could be a cause. I would also check the rubber diaphram on the fuel pump. If the diaphram fails, it can leak gas directly into the oil pan...
wild4stangs is offline   Reply With Quote
09-25-2002, 08:26 PM   #3 (permalink)
billy
Gasoline In Oil???
I would have to say it is the mechanicle fuel pump..... Quick and easy to replace....
billy is offline   Reply With Quote
09-25-2002, 08:58 PM   #4 (permalink)
Otto
Gasoline In Oil???
Could also be blow-by caused by worn out rings. You would also have low vacuum if it was this. If you are unsure try a compression test.
Otto is offline   Reply With Quote
09-25-2002, 09:02 PM   #5 (permalink)
n2omike
Gasoline In Oil???
My dad had a 79' Jeep Wagoneer with the 360 engine. It's mechanical fuel pump failed somehow, and pumped the crankcase full of gasoline.
Good Luck!
n2omike is online now   Reply With Quote
09-25-2002, 11:11 PM   #6 (permalink)
jerrys63
Gasoline In Oil???
I think if you were running that rich the car wouldn't idle or run right. You robably have a leaky fuel pump.
jerrys63 is offline   Reply With Quote
09-25-2002, 11:52 PM   #7 (permalink)
BLACK65FORDFALCON
Gasoline In Oil???
My Edelbrock fuel pump only has approx 500 miles on it. It does not appear to be leaking. When I went and picked up my car today my mechanic had saved a little cup of my 20/50 oil, It was as thin as water and completley stunk like gasoline. I did have a compression test done as well and I was between 145 and 150 on all cylinders.
1965 ford falcon
280 H comp magnum cam
Edelbrock carb/Intake/Feul pump
Hedman Headers/Flowmaster mufflers
302 Bored .30 over
MSD Ignition
4 Speed Toploader
Richmond 4.11 gearset
<font size=-1>[ This Message was edited by: BLACK65FORDFALCON on 9/26/02 10:55am ]</font>
09-26-2002, 04:50 AM   #8 (permalink)
TurboCoupe50
Gasoline In Oil???
I agree.
TurboCoupe50 is offline   Reply With Quote
09-26-2002, 07:43 AM   #9 (permalink)
Cobrajack
Gasoline In Oil???
BLACK65....
I have had THREE EDELBROCK, $150.00 water pumps on my Cobra since I built the 408W....so don't rule out a bad fuel pump from the factory!!!!
Call the supplier and have it replaced and I'll bet your problem goes bye-bye??!!
You could also just buy a stock one and try that first.....won't take long and they are pretty cheap.
Good Luck,
Cobrajack
Cobrajack is offline   Reply With Quote
09-26-2002, 11:23 AM   #10 (permalink)
BLACK65FORDFALCON
Gasoline In Oil???
Thanks everyone who replied to my post. I am going to look into this feul pump situation and give edelbrock a call in regards to exchanging it.
