c4 torque converter stall
With the double-pumper and single-plane intake on a small displacemet engine, you'll probably appreciate a 2500 stall better. Stock stall is probably around 1400 rpm. WIth a cam at 218 intake duration, you are on the bubble for needing more stall even if you had a vac sec carb and dual plane. I had a pan-fill C4 with a stock converter (about 12" in diameter) behind my mild 351C. It launched pretty lazy, even with the 3.55 gears. I put a case-fill C4 trans in with the stock-stall 11" converter, and the launch was better. Put the 2500 stall 11" in for more fun but worse mileage.
