09-27-2002, 04:33 AM   #1 (permalink)
ed351
Do eibach drag rear springs and southside lowers work with a light mustang?
ICar wants to squat alot even with 90/10 and moroso front spring. Was wondering if the spring wasn't getting compressed enough because car is lightened up alot in rear. Also they set in there bowed a little which I would think would change the spring rate a little. If i put 20 lbs of air in the right bag it hooks alot better originaly but later spins do to not enough weight staying tranfered to the rear. Car is a 85 mustang weighs 3050 w/me and run 6.80s in 1/8. When running nitrous the suspension really works , I think the extra torque causes it to lift in the rear instead of dropping. I amost forgot to mention i am using a c4 with brake which makes it some reason a lot harder to hook when not running the juice???
<font size=-1>[ This Message was edited by: ed351 on 9/27/02 3:54pm ]</font>
ed351 is offline   Reply With Quote
