09-29-2002, 09:57 PM   #1 (permalink)
Nooneyet
Stock 351 block *1978*
I have been told you have to have an aftermarket block to do 5's in the 1/8th but yet there is 4-5 guys doing it at my local track.
My question, WILL a stock 351 W block with a girdle hold a 275 plate kit with a 408 stroker, maybe even 418.
Nooneyet is offline   Reply With Quote
09-29-2002, 10:45 PM   #2 (permalink)
SteeLDawN
I'd personally use a Cleve block, rather than a windsor, as they were built stronger.
SteeLDawN is offline   Reply With Quote
09-30-2002, 12:06 AM   #3 (permalink)
n2omike
351W's are stronger. 351C's suffer from thin cylinder walls and an inferior (comared to the 351W) oiling system. The 69-74 351W blocks are the strongest, but be aware that the 69' blocks have a shorter deck height. They are around 0.020" shorter @ 9.48".
However, I have a buddy who pushed a 79' block in a 3000lb fox body to a 5.92 @ 121 in the 1/8 on two stages of nitrous. This was with a cut down, stroked 400 crank and Chrysler rods in a 426. [img]/phpBB/images/smiles/icon_eek.gif[/img]
You'd blow the cylinder walls out of a 351C trying that if the block wasn't filled.
Good Luck!
n2omike is online now   Reply With Quote
09-30-2002, 02:01 AM   #4 (permalink)
dacofa
Use good rods and oiling system. ARP rod bolts, main studs with a girdle and you'll be running with the big dogs. Use a good oil pump driveshaft.
09-30-2002, 02:09 AM   #5 (permalink)
Nooneyet
Well, what rpm was he turning? can you release the type of heads he was running? any port work? any of that would help alot in consideration.
If I do it, it will be a 426 kit with a girdle and good stuff.
09-30-2002, 08:13 AM   #6 (permalink)
n2omike
426W, offset ground 400 crank, Chrysler rods, 252/262 solid roller, dished pistons ~11:1 cr, BIG ported TFS Hi-Port heads and Vic Jr. intake, 2-stage nitrous, C4 trans w/brake, 8.8 rear w/3.73 gear, 1-7/8" headers, 3000lbs w/driver, shifted no higher than 6500rpm. Usually closer to 6k.
The engine ran flawlessly for two years like this before the shortblock was sold to a guy who bracket raced it for a while.
He was always VERY conservative with the timing. This, along with the lower compression are (in my opinion) what allowed the engine to live so long. This has been 6-7 years ago.
Good Luck!
