exhaust options for 1969 428 super cobra jet
Go with dual 2.5 pipes use the xpipe or cross tube, that is good for low end grunt, then use 2 chamber Flowmasters do the N20 Mike trick of welding header flanges there then buy the flowmaster"mandrel bent"over the axel pipes so you can run them dumping in front of the axel or out the back when the hearing starts to go!
