10-07-2002, 03:13 AM   #1 (permalink)
Tigly2
347 or 408 Stroker?
I have a set of 69 Boss 302 heads (2.23 int & 1.71 exh)that I would like to put on a stroker motor. Originally I thought of putting them on a 347 or 355 cause I also have a Boss block. My ultimate goal is 600fwhp. I have read in these message boars that 600 is obtainable from the 302 block. I do realize that a 408 in a windsor block would make things much easier. My question for now is: block strength - how does the 2 bolt mains of the windsor block compare to the 4 bolt of the Boss block? This engine does NOT need to be streetable. If anyone has any parts combinations that would help me achieve my goals, please feel free to pass them on.
Tigly2 is offline   Reply With Quote
10-07-2002, 06:15 AM   #2 (permalink)
giddyup1
347 or 408 Stroker?
408 is the go,but if you have money to spend svo or dart 351 block would be better
giddyup1 is offline   Reply With Quote
10-07-2002, 11:56 AM   #3 (permalink)
mustangzrule
347 or 408 Stroker?
600HP 302/347 is kind of difficult, doable, but you should consider forged crank, strong rods, like H beams, no question about ARP bolts, forged pistons, girdle, studs instead of bolts for mains and heads, o-ring gaskets, etc. I asume your boss block can handle it?
I forgetting anything?
408W can more easily do the 600HP but is close to the upper limit for what I personally would do with a stock block. I don't have the experience of some of the board members here, but that helps me err on the safe side. $ up front saves $$$ down the road is my rule of thumb.
No matter what block you use, the ARP replacement fasteners are a must, especially on the rods.
I don't know about the heads producing 600HP in any motor without extensive work. If it is even possible.
<font size=-1>[ This Message was edited by: mustangzrule on 10/7/02 10:57pm ]</font>
mustangzrule is offline   Reply With Quote
10-07-2002, 02:44 PM   #4 (permalink)
deleted
347 or 408 Stroker?
610 hp @ 6800 rpm..........544 ft lbs tq @ 5100. 418 cubes. stock block. AFR 205 heads
Chilly, step in here.................[img]/phpBB/images/smiles/icon_biggrin.gif[/img][img]/phpBB/images/smiles/icon_wink.gif[/img]
deleted is offline   Reply With Quote
10-07-2002, 06:52 PM   #5 (permalink)
n2omike
347 or 408 Stroker?
A stock 351W block is stronger than a Boss 302.
You'll have to build one WILD and EXPENSIVE 347 to make 600hp. A 408 will do it much more easily and reliably.
Go with the 408...
Good Luck!
10-07-2002, 07:11 PM   #6 (permalink)
coolfalcon
347 or 408 Stroker?
put your boss 302 heads on the 408 stroker.
10-08-2002, 02:13 AM   #7 (permalink)
460 Tom
347 or 408 Stroker?
Day One, Hot Rodding 101, Lesson One : Start with the largest cubic inch platform your chassis will accept. End of lesson.[img]/phpBB/images/smiles/icon_biggrin.gif[/img][img]/phpBB/images/smiles/icon_biggrin.gif[/img][img]/phpBB/images/smiles/icon_biggrin.gif[/img]
460 Tom is offline   Reply With Quote
10-13-2002, 07:38 PM   #8 (permalink)
Tigly2
347 or 408 Stroker?
Thanks for everyones input. Your opinioins will influence my descision alot. Here is a little bit of information that I thought was interesting and worth passing on: according to Ford Motorsports, their 302 4 bolt main block has a recommended MAX HP of 1200 @ 8600 RPM - their 351 4 bolt main block has a MAX 750 HP @ 8500 RPM !!! The 351 has one more 4 bolt main cap than the 302. Wouldn't this suggest that the 4 bolt 302 block would be MUCH stronger than the standard 351 with 2 bolt mains?
10-14-2002, 02:02 AM   #9 (permalink)
lordviper13
347 or 408 Stroker?
you are compareing the siamesse block to the non siamesse one
I hear that dart makes some really nice blocks for ford now
lordviper13 is offline   Reply With Quote
10-14-2002, 01:32 PM   #10 (permalink)
Steve
347 or 408 Stroker?
What kind of intake manifold will you use? I have never seen on for a 351 clevor.
Steve is offline   Reply With Quote
