10-19-2002, 12:50 PM   #1 (permalink)
machI1973
HELP NEED 9" Rear end with Disc Brakes
I am looking for a rear end that will fit into my mach I and have disc brakes. I have gone to this website http://hiqties.hypermart.net/9inch.html#links but they dont not say anything about what types of breaks belong to each rear end. I do not trust the junkyard to look for it, they will take forever.
machI1973 is offline   Reply With Quote
10-19-2002, 03:49 PM   #2 (permalink)
HankyJ
Check out the Explorer 11" rear disc swap. It's quite reasonably priced and you'll have new components, and I think they're lighter than the older style stuff that you'll be lucky to find at a junkyard. In the end you might end up actually saving $ and coming out with a better finished product, over rebuilding a junkyard disc brake set up, etc.
10-19-2002, 08:44 PM   #3 (permalink)
gtnrb71
hey I was told the explorer disc kit will only work on late model cars. So for my 71 torino I bought these brackets off ebay. They use lincon rotors, and cadilliac calipers with built in parking brakes. It cost around 300 for all and works great with little fabrication. go to ebay and then type in rear disc brakes and you will find the brackets. Hope this help.
gtnrb71 is offline   Reply With Quote
10-20-2002, 11:18 PM   #4 (permalink)
ChicoB
There is also a nice swap that I'm going to try using Lincoln LSC rear discs. Go to www.ultrastang.com He sells brackets for $90 and uses all ford (lincoln) parts.
Probe Industries
