11-04-2002, 05:16 PM   #1 (permalink)
66KingCobra
Fuel Injectors
I was wondering how much fuel does a 500 cfm 2bbl carb flow and could any 2 fuel injectors folw at the same rate or would it require more injectors? One last thing, whats the difference between TBI injectors and standard injectors?
Thanks,
Charles
Pushrods and Carburetors! The way it should be =).
<font size=-1>[ This Message was edited by: 66KingCobra on 11/6/02 1:23am ]</font>
66KingCobra is offline   Reply With Quote
11-05-2002, 01:30 PM   #2 (permalink)
HitmanKB
Fuel Injectors
I dont know the difference between the TBI injectors and standard fuel inectors, but there shouldnt be that much difference between the two. All I know is that you can go up in rate on the standard injectors.
HitmanKB is offline   Reply With Quote
11-05-2002, 07:40 PM   #3 (permalink)
Racing
Fuel Injectors
I´m not sure what it is you´re asking?
If it would be feasable to put a two barrel TBI on your motor?
Racing is offline   Reply With Quote
11-06-2002, 10:35 AM   #4 (permalink)
66KingCobra
Fuel Injectors
thanks,
11-06-2002, 03:51 PM   #5 (permalink)
Racing
Fuel Injectors
It´s like night and day.
The TBI units are normally massively flowing units that are clumpsy(sp?) in apperance.
A "standard" injector is basically set up for port injection work,whilst a TBI injector is what you might call an "electronic carb" kinda deal.
This also shows up in the OEM linepressure settings.
A TBI unit normally comes in at about 9-13psi and a standard one ranges from 35 and up.
All in all these are two different creatures.
Likewise the TBI unit will take a special housing for a fuelrail while a standard one connects to a fuelrail either via an o-ringed firring or a hose.
As far as i know the TBI units are high impedance units all the way,the standard injectors can be had as high or low(satured or peak and hold)
The list goes on...
11-06-2002, 04:10 PM   #6 (permalink)
Doc
Fuel Injectors
Ford injectors are high impedance (Saturated)
Doc is offline   Reply With Quote
