What would it take to run 7.50's with a 460
A buddy of has an engine like this in his 69 Mach 1. It's gutted, so it's a little lighter than normal weight. About 3000 -3100 lbs w driver. It runs 7.20's in the 1/8.
Combo: .030 over 460, TRW forged mini-dome pistons, stock crank and rods + good rod bolts. Hyd flat tappet cam. .560 lift 246° @ .040. Home ported DOVE heads, roller rockers, out of the box Offy Port-O-Sonic intake, very old 850 Holley DP carb, Duraspark dist w/ MSD 6AL box. Runs an alt and an electric water pump drive. Car has a C-6 with full man valve body, 10" 4400 stall converter. Header Total Performance conversion headers with Dynomax race bullet mufflers. Runs 4.56 gears, 28.5X 10.5 MT slicks. Shifts it at 5900 rpm.
It runs 7.20's @ 94 on the motor when bracket racing. He plays around a little with some heads up stuff and nitrous. It has gone easy 6.80's @ 102 on a 150 shot.
