Closed Cap or Breather?
OK ... I get kicked in the head every time I get involved in this discussion, but here is my two cents ... and trust me on this one ... "It ain't Rocket Science".
Lordviper hits the nail on the head ... No one has rings that seal 100%.
Because of that, every engine will generate internal pressure no matter what.
Eventually that pressure must escape and it will ... whether its through your seals (creating oil leaks as it goes) ... or through open breathers of some sort or through some assited evacuation method, namely a "Draft Tube" ... "Positive Crankcase Ventilation" ... or some "Mechanical Vacuum" system.
Point #1 would be ... I'm not so all fired sure how important it is to have a so called "Fresh Air Inlet" as a part of this system ... Not that I think it's a bad idea, but logic (and simple looking at running engines) tells me the pressure inside the engine is going to be escapeing through that "Inlet" more often than any fresh air will be comming in through it.
My sense of it is that as long as that pressure can make a "Free Flowing" escape without creating pressure on the seals within the engine ... you've got it 95% whipped ...
Obviously, the EPA has some ideas of what it thinks is safest for the environment and I will agree that if you can create some sort of directionl flow via vacuum, from a draft tube or some other means, that it will assist the process.
I know guys will say that Gasoline vapors will accumulate in the crank case and dilute your oil if you don't run some sort of vacuum evacuation ... but dang, if you have that much blow-by you have problems bigger than crank case evacuation and you are probably having to refill the oil (if your rings are that bad you must be burning a ton of it) often enough that you are "un-diluting" it as fast as your blow-by is diluting it.
In the final analisis ... My thinking is that as long as the pressure can "exit freely" and I do regular maintenance on my engine I'm happy.
I do not run "PCV Valves" in any of my engines because I think is is just one more place to have a "tuning" problem. I also don't vent directly into the environment either.
OK ... I've grabbed my ankles ... You'all can start Kicking
BTW if you want to kick me in the head, it's out front ... the boney thing in the back is my A$$ [img]/phpBB/images/smiles/icon_biggrin.gif[/img]
Larry Madsen
Las Vegas Nevada
<font size=-1>[ This Message was edited by: monstermach on 11/15/02 7:39am ]</font>
<font size=-1>[ This Message was edited by: monstermach on 11/15/02 9:09am ]</font>
<font size=-1>[ This Message was edited by: monstermach on 11/15/02 9:14am ]</font>
