11-13-2002, 10:52 PM   #1 (permalink)
rj
ROCKER ARMS >> 1.6 OR 1.7 ...HOW DO I IDENTIFY?
I HAVE A SET OF ROLLER ROCKER ARMS THAT ARE MARKED CRANE CAMS/FORD F3ZE-6529 AB ...AND I WAS CURIOUS IF THEY WERE THE 1.6 OR 1.7 RATIO? THANKS FOR ANY HELP,.
my everyday street racer:
'91 gt, 357", track heat heads, victor efi upper/lower, custom comp cams retro roller, nitrous works 260 hp 2-stage plate, 3800 10" no2 converter, holley digital ignition, bbk/edelbrock 75 mm throttly body, homebuilt c-4 (...a big thanks to gregaust) 4.10 gear.
<font size=-1>[ This Message was edited by: rj on 11/14/02 9:54am ]</font>
rj is offline   Reply With Quote
11-13-2002, 11:07 PM   #2 (permalink)
DblADigger
'Er, are you SURE about that part #?. Ford rocker arms are P/N....-6564-.... You might want to call Crane's tech line and ask them.
DblADigger is offline   Reply With Quote
11-14-2002, 08:50 AM   #3 (permalink)
rj
yep, i'm certian on the part numbers..there casted in the rocker. the rocker looks like the crane cams energizer piece. i will give crane a call today. thanks.
