rubber spring coushions cougar
That is correct, the axle would rest on the spring, if you remove the rubber spring cushion. Mustangs do not have a bracket on the top of the spring like the Cougar.
I added a 1" lowering block (for a Mustang) between the spring and axle which I thought would compensate for the spring cushion thickness. Also you may need to change to the Mustang shock plates.
