1989 Mustang LX w/Tremec (TKO) and 3:55 gear.
Thats a pretty stout motor for a EFI combo.
You'll need a big intake... either a vic jr efi, or something like a TFS track heat... or even consider a box upper and truck lower.
Throttle Body... at least 77mm, 80 if you can find one. Same goes for the mass air.
Injectors... I'm guessing 36lb/hr will be safe.
The A9L will get you running, but with much displacement and air flow, you really should get it on a dyno with a wideband sensor and a chip tuner and have a chip burned. Otherwise, if you are really adventerous, get a ECC tuner and laptop and try your own tuning.
