11-25-2002, 12:39 AM   #1 (permalink)
shamu
detroit locker to 31 spline
I have a 28 spline detroit locker I was not going to use . is it possible to just change the internals to 31 spline?
shamu is offline   Reply With Quote
11-25-2002, 09:50 AM   #2 (permalink)
Just Strokin
Yes, if you can find the internal gears the axle slips into.
11-25-2002, 11:36 AM   #3 (permalink)
n2omike
I have no experience with doing this to a Detroit Locker, but it will not work with a trac loc.
The 31 spline axles are larger in diameter, and will not fit into the 28 spline trac-loc case.
I HAVE seen dirt track guys bore the 28 spline units out for 31 spline axles (when installing a 31 spline mini-spool) with no problems, but have not done so myself.
Good Luck!
