Would a machine shop have caught this? If not, what can I do?
While it is possible for the outer ring of the damper to "slip", IMHO, I don't think that it happens as often as it is talked about (I could be wrong though). Further, the counter weight for engine balance is typically on the casting (not the ring that slips); at least it is on the 28 oz dampers that I have seen. Has the front cover been changed? If so, perhaps the pointer is in a new location that is not compatible with your damper. Just some thoughts.. not much help.
