Brake Installation ... In rememberance ... read first post edit
Is that the kit where you use a bracket from steeltech solutions on the rear, mount late 80's Lincoln rotors, and mid eighties cadillac calipers? Sure sounds like it is, I just installed those on my mustang. The bleeders are too low when mounted to get all the air out. Mine work great. I used a transam racing power booster and master cylinder for an early mustang with manual trans, stainless steel front disc conversion, and the above for the rear.
I still cannot get the front brakes to work as aggressively as I like. I am beginning to think that the SSB conversion calipers are not that great. It takes a ton of pedal effore (even with the power booster) to get the front brakes to lock. They are somewhat better after I changed to semi-metallic pads. Just thinking out loud here, has anyone else here run into the same problem with the front brakes? My 11-year old runs down the street everytime he sees a can of brake fluid. He has spent a lot of time pushing the pedal.
