On 2002-12-18 20:28, Billgear wrote:
I have a 302 with AFR 165cc heads. I've been toying with idea of useing a 331 stroker kit to get a little performance boost. I really don't want to port my heads, but i could (have it done) if needed.
The car is used for open track style driving and some street.
Regards,
BillGear
http://www.289mustang.com
Those heads will do very well up to your max rpm of 6200. In addition, those heads will provide excellent torque with smaller 165 cc runners. I'm using ported 351W heads that have 160-165 cc intake volume and their great up to 6500 rpm. Flow with my heads are 220/180 @ .500. Your's are probably better so go for it. The best performing heads are the one's with the smallest runners possible with the highest attainable flow. What is your cam's advertised rpm range? If you want something that will do the job up to 6200 rpm, go with a Comp 280H or 282S minimum (flat tappet cams) if your cam is not rated that high.
