Adjusting the clutch: Throwout Bearing and Clutch Fingers!
Time to adjust the pedal to where it will actually disengage the clutch. As of right now, with the clutch pedal fully pressed in, it only begings to disengage the clutch about 2 inches off of the floor. Upon this, it will return the clutch pedal back to that 2" off of the floor. Now the question is, is it okay if the pilot bearing is pressed against the clutch fingers? The clutch is a Dual friction Centerforce, and the throw out bearing that Center Force recommends with their clutch. My dad feels that we read somewhere with this clutch that the throw out bearing should NOT be on the clutch fingers. However, he always thought that the throw out bearing was always spinning. Help Please!
Thank you!
Jeff Given
