Top loader trans, Close ratio\wide ratio
With slicks, the car will be quicker with the lower 1st geared wide ratio box. On the street, where traction is a problem, the taller first gear will put less torque to the ground, and help keep the tires from spinning.
With traction, you want the lower first gear, without bit it does you no good.
Off the bottle (on slicks) my car will bog with a wide ratio box and 4.33 rear, even when launched at 6800 rpm. Nitrous fixes that. [img]/phpBB/images/smiles/icon_wink.gif[/img] 60ft's go from mid 1.6's to a best of 1.43 when the juice is turned on. [img]/phpBB/images/smiles/icon_biggrin.gif[/img]
Good Luck!
