01-08-2003, 06:19 PM   #1 (permalink)
bag514
460 water neck
I just purchased a Ford Motorsport water neck (chrome with o-ring). It has a threaded hole in it that I believe is for a temp. controlled vacuum port (emissions).
My problem is that I need to plug this hole.
I tried to us a 3/8 npt plug but it is a little to big. I can't seem to find the right size plug.
Does anyone know the correct size of this hole or should I just tap it for the 3/8 plug.
Any help or suggestions would be great.
Thanks in advance
bag514 is offline   Reply With Quote
01-08-2003, 08:02 PM   #2 (permalink)
Just Strokin
460 water neck
I would think it is 1/4 npt.
01-08-2003, 08:18 PM   #3 (permalink)
bag514
460 water neck
I should have mentioned this initially
I also tried:
1/4" npt = to small
-6 sae = to small
-7 sae = to big
It doesn't seem to be a standard size.
That is why I am having trouble.
01-08-2003, 08:46 PM   #4 (permalink)
Silverliner
460 water neck
The threads are 5/8-18. I know because I just checked the same part I had received from Summit yesterday after reading your post. I am not sure how I'll plug it, probably 3/8 inverted flare cap with some sealer. 'm also not sure what sort of sender this is made for, certainly not my old 429 stuff.
Silverliner is offline   Reply With Quote
01-09-2003, 08:14 PM   #5 (permalink)
mustang68mustangs
460 water neck
I had the same dilemma.I used a 3/8" inverted flare fitting and put a little JB weld around the threads. it has worked perfect for 3 years so far.
Bob
mustang68mustangs is offline   Reply With Quote
01-09-2003, 08:42 PM   #6 (permalink)
FoMoCo
460 water neck
I used a flat head brass plug which I think I got at napa.
01-13-2003, 03:37 PM   #7 (permalink)
DblADigger
460 water neck
Mine came with a chrome plated plug and seal ring/gasket. Yours should have come that way also.
DblADigger is offline   Reply With Quote
