Heated carb spacers?
More on the carb spacer thing:The parts I used were OEM, Ford sold both a two and four hole spacer over the counter. They were about 1" thick but there is one hitch in the works, if you use them on any intake manifold other than factory, you'll have a giant vacumn leak, they have a wierd factory only shape on the base. You could use them on aftermarket manifolds but you would need to also use a plain two or four hole spacer, plain aluminum plate, and gasket between the manifold and the Ford spacer. Hope this helps, Gary Gordon
