01-18-2003, 08:03 AM   #1 (permalink)
428scj67fairlane
428scj min. oil pressure.
What is the most common min oil presssure
a 428 has at an idle? new rebuild i have
only 20psi hot at an idle the engine is
a scj .060 over alum. heads and a solid lifter cam. bearing clearance is .0015
should this engine come apart to check
or is this normal???[img]/phpBB/images/smiles/icon_confused.gif[/img]
428scj67fairlane is offline   Reply With Quote
01-18-2003, 04:30 PM   #2 (permalink)
Mario428
Need some more details. Type and weight of oil, hi-volume or regular pump. Engine temperature when the oil pressure is low.
01-18-2003, 04:52 PM   #3 (permalink)
FE427TP
Ford engineers used to say 6 psi at idle was minimum. But I have no written proof of this
FE427TP is offline   Reply With Quote
01-18-2003, 05:55 PM   #4 (permalink)
Nastystang
you have more oil pressure at idle than I have had in all my FE pwered vehicles. My old truck had about 5
01-23-2003, 07:19 PM   #5 (permalink)
Cyclone Joe
10 psi per 1000 rpm. The purpose of oil is to cool the bearing surfaces. At low rpm, little heat is being generated so your oil pressure is fine.
Cyclone Joe is offline   Reply With Quote
