02-02-2003, 12:39 PM   #1 (permalink)
coolfalcon
Cam special
Has anyone heard of a cam from crane called a Tight lash special? Its a solid with what the spec card says to lash them at .012.
02-02-2003, 03:14 PM   #2 (permalink)
frankenfords
Cam special
The theory behind the tight lash cams is that they shorten the time in degrees it takes to go from .020" to .050" lift. A fast moving ramp will produce more torque and breath better at higher rpms. The duration at .200" is generally greater with a tight lash cam. Tight lash cams are fairly popular with the circle track crowd.
frankenfords is offline   Reply With Quote
02-02-2003, 04:36 PM   #3 (permalink)
coolfalcon
Cam special
Thanks i got this cam from a nascar guy.
