302 knocking
yes it's possible to change both, so long as the crank/block/rods are not damaged. I would also check the clearances while your in there. FYI a good rule of thumb on engine noises is generally if it's a main bearing it will make a "thud" noise, just like hitting the end of the crank with a hammer. A rod is more of a dull tapping noise that most often makes it's noise cruising at part throttle--usually goes away when accelerating/decelerating. I would be willing to bet that the pistons are making a bit of noise as you describe it going away when it warms up. Rods and mains wont usually go away with heat like that. Cam bearing damage will show low oil pressure, but usually wont make much noise.
