clutch clearances on transbrake c-4
I am rebuilding a transbrake c-4 and was wondering if I need to do anything different with the clearances? Also on a transbrake c-4 are the forwards hit hard when you release the button? I am new to transbrakes so please forgive my ignorance. Doesn't the brake hold reverse and low at the same time, then slam it into low. The transmission had regular Raybestos clutches 5 and 4. The clutches and steels measure close to stock, but clearances were extremely excessive. .072 on the 4 clutch hi/rev and .062 on the 5 clutch forward, endplay was .065. I wondered if someone had rebuilt before and had not set clearances or set them extremely loose to start out with. I figured the tighter the better, but I figured I would ask the pros. Thanks.
