suspension
The 600's are very rough. I'd look at 420 regulars or 500~ progressive rates. A 1" front and MAYBE a small (like 1/2) rear bar should do well. Actually, no rear can work to. Doing the Shelby mod (1" control arm drop) to the front is recommneded - this does NOT lower the car. Unless you're flush, rebuilding the stock arms is the way to go. If you intende to drive really hard, boxing the lower arms is a good idea. Stay away from poly strut rod bushings as these are getting a rep for breaking the rods. With the Shelby mod, rebuilt arms and a 1" front bar mounted in poly, just about any good gas shock will work well. The KYB's are a top end shock. Also, do a good front alignment, using 2+ degrees of caster to help the car track good. Go find the March 2003 issue of Mustang's and Fords - lots of info in that one.
