02-11-2003, 02:52 PM   #1 (permalink)
torino420
Converting from auto trans to manual
Just curious on general parts list. For 69 torino.
I know i need the brake and clutch pedal assemblie but what else.
thanks
torino420 is offline   Reply With Quote
02-11-2003, 03:09 PM   #2 (permalink)
Just Strokin
Z-bar and mounting points
linkage from clutch pedal to Z-bar
linkage from Z-bar to throw-out fork
diveshaft?
yoke?
speedo cable
transmission crosmember
clutch pedal assist spring
and the obivious items
flywheel with correct balance
clutch disc and pressure plate
throwout bearing
bellhousing w/throwout fork
manual transmission
shifter
also correct bolts, screws and nuts (pressure plate uses a special bolt).....and a lot of time and probably a lot of items I forgot.
02-11-2003, 04:43 PM   #3 (permalink)
64 TBOLT
dont forget the pilot bushing[img]/phpBB/images/smiles/icon_rolleyes.gif[/img]
02-12-2003, 03:36 AM   #4 (permalink)
RPM
Hey Torino, which tranny are you swapping, and do you wish to unload it?
02-12-2003, 04:30 AM   #5 (permalink)
knifeman85
the correct bell housing, because it will not usually come with the transmission
knifeman85 is offline   Reply With Quote
02-12-2003, 05:10 AM   #6 (permalink)
dark7068
make sure you have a fairlane tailshaft too. A mustang/cougar one is different in where the shifter bolts on.
dark7068 is offline   Reply With Quote
02-12-2003, 11:49 AM   #7 (permalink)
torino420
RPM: C6
But this more then likely won't happen any time soon.
